savin 8045e sc322
  • shawn
    • Aug 2025
    savin 8045e sc322
    broaght machine to shop to do a pm. 50 mile trip. removed everything but laser unit and blew machine out as it was very very dirty. after doing pm pwr up and get sc322 OK so blowing out machine with laser unit in wasn't a good idea. removed laser unit and cleaned everything up three times, still get sc322 replaced LD board and Laser sinc board. did sp110 and sp109 still get sc322 didn't get this sc until after machine got here. HELP!!
    shawn
  • D_L_P
    Self Employed
    • Oct 2009
    • 1196
    I don't think this has a shutter, but there are 4 safety switches for the laser. 2 on the front door and 2 on the transfer door. Are they working properly? All that moving might have displaced one.
    • Llama God
      • Mar 2009
      • 1353
      You've broken it!
      Do you have another laser unit to try in the machine? I don't mean individual boards, a whole laser assy. If not, can you get into SP mode and do the auto pitch adjustments for 400 and 600dpi? If so, can you hear the ticking/groaning noise when it does this adjustment?
      I'd also check the door switches as DLP said.
      • shawn
        sc322
        I have checked the V @ pin 1&3 on cn 403 of the LD board and I have 5V
        I think that is after the safty sw so they should be working right??
        or am I missing something their?
        No Dont have a complete laser unit except out of a 2535 going to try and switch LD boards and see if I can get it to work today.
        anymore ideas greatly appreciated as I am out of ideas.
        thanks
        shawn
        • shawn
          Oh ya! I can hear the LD motor when I do auto pitch adj.
          • shawn
            OK just got through putting laser unit out of 2535 w/LD board of 8045 in and mach. works great.YEH!!
            I think what happened is when I cleaned all the toner dust off of the reflector in the laser unit I scratch them. they are not made of glass much to my surprise.
            thanks for the help and ideas I love this site.
            thanks again
            shawn
            • ferastec
              • Jun 2009
              • 107
              It is happened to me today, 1045,,,, after replacing the drum and PM parts, the toner was dropped all over the machine, I cleaned it well then SC322 and SC326, came.
              I am really upset from this design, every thing are great in this machine except the laser issues., any other solution can solve this issue without changing the LD unit or the full laser housing.
              I can change it but this is not the solution!!!! It is too costly.
              Advice plz
              • TonerMunkeh
                Professional Moron
                • 3865
                Usually blown laser units on these filthy pieces of poo are caused by them being drowned in toner. The C4 variant seems to be the worst for this. Unfortunately if you are getting constant 322 / 326 even after replacing all 6 door switches you have to replace the entire laser unit. There's no other way around it.
                Hit it.
                • olsong
                  • 24
                  Is it possible to buy a complete laser unit? If so does anyone know the part #?
                  • zyqwiz
                    • Jun 2009
                    • 333
                    I've got no idea what Savin models are but on the old 35/45 machines with SC322 you had to loosen the screws then crank the laser unit up a bit - something to do with the detector slot being too small - that was on a technical bulletin too!
                    • Venom
                      Technical/IT Support
                      • Nov 2009
                      • 765
                      Advice plz
                      Sometimes you can pry up on the right side of the laser box and tighten to correct
                      IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
                      • olsong
                        • 24
                        Purchased a reconditioned laser assembly unit from Hytec and installed it. Machine works fine and is delivered to customer.
                        Thanks for all you help.
                        • Joelzkie
                          • 37
                          try this
                          perform SP 2-109 to adjust the laser beam pitch
                          SP2-110 Test Mode Dpi (0: 400 dpi, 8: 600 dpi)
                          SP2-109-1: LD Beam Pitch Adjustment . 400 dpi
                          SP2-109-2: LD Beam Pitch Adjustment . 600 dpi
                          SP2-109-3: LD Initial Setting . 400 dpi
                          SP2-109-4: LD Initial Setting . 600 dpi
                          1. Set SP2-110 to 0 (0: 400 dpi, 8: 600 dpi)
                          2. Do SP 2-109-8.
                          3. For SP2-109-1 input 144.
                          NOTE: The entry .144. is only a starting reference value that will allow the
                          machine to operate. It is only a starting point for adjustment.
                          4. Perform SP2-109-3.
                          • Koosie
                            • Nov 2008
                            • 121
                            Open the laser unit and clean the small rectangular glass next to the laser diode. It's the first thing the laser goes through. I have seen a lot of them that is dirty. BEFORE YOU REMOVE THAT GLASS, mark the top part and return it in the original orientation, else SC-322 will appear.
