smudging only occurs on letterhead paper and anything over 100gsm.
letterheads are placed in the normal cassette trays setted on letterhead in usertools. this cured the problem for a short while.
have also adjusted the temperature in the fuser unit as stated in the RTB 7. SP1-912-2 and SP1-916-1 have been adjusted as stated in the rtb.
machine does get used alot throughout the day. only done 300k. all parts are still within pm. the only thing i can think of now is replacing the fusing oil with a heavy duty oil supply.
has anyone else had the same problem??
