In my 1060 I suffer form having light or weak in the top area , and good quality in the bottom area of the image . when copying on Glass or ADF
Weak ( light ) in the top area of the image in 1060
The filter on the dev unit is probably not sitting in properly, it sprays toner on to the laser slit glass.IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ CertificationsComment
Blockages on the doc blade, worn developer, worn seals, plugged filters, and dirty coronas can also cause toner to dust the laser glass. Point being that if cleaning the glass fixed it you've got more work to do finding what scattered toner to the laser or you'll be back to this machine in real short order.73 DE W5SSJComment
What about damp paper? I know it's a long shot for paper to be damp on one side only, but sometimes people store paper in weird ways. Try turning the paper around 180 degrees and see if the light area follows.But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
He stated he fixed it. Looks like it was the laser glass slit, now he needs to fix the cause. But I have seen damp paper do totally blank or very weak copies.Comment
Probably the development roller is dirty.
Remove de developer from the unit and from the magnetic roller. See if in the edges is darkerComment
