Papers not ( jogged well ) in aficio 1060 finisher.
  • aaahmmm
    • Aug 2009
    • 103
    I have a problem in 1060 finisher , when I have to sort using finisher shift tray , the output is not tidy ( jogged well ). Paper up and down in the same set .
    What my cause this.
  • zed255
    How'd ya manage that?
    • 1024
    Worn out sponge exit rollers in the finisher exit assembly. They pull the pages back to keep them neat. Once they wear down the finisher won't stack well.
    • Lagonda
      • Aug 2008
      • 1649
      Also check for paper cuts in the plastic jogger guides. A single sheet of paper can hang up in the fine groove cut in and not drop to the bottom therefor missing the stapler.
      • Ricoh-ono
        • 340
        Jogger fences in older models would crack along the corner. They redesigned by adding ribs for support. This used to be one my biggest headaches. Good luck!
        Do what you can, with what you have, where you are. ~Theodore Roosevelt
