1045 Charge Roller Voltage error
  • nobody-here
    • Mar 2008
    • 237
    hi everybody,
    I have a ricoh 1045 keeping a strange issue.
    Charge Roller voltage goes up to 2000 without reason.
    Even If i modify Charge Roller voltageSP2-001-001 to 1480 (default value), after a few moments, if I turn off / On machine it comes up to 2000 so copies are too light.
    Lowering voltage to 1480 copier are ok.
    I changed ID sensor, drum, developer.
    Any other clue or info about this.
    Vincenzo
    29 rouge unpair manque.... cous cous....
  • Fearless V K
    • 620
    Sounds like the machine process control is changing the value to compensate for other issues.
    Don't take that toner with me!
    • nobody-here
      • Mar 2008
      • 237
      What can I check?
      • Eric1968
        • 2458
        Did you also replace the charge roller itself?
        • Fearless V K
          • 620
          Check your (ID, TD) sensor readings. If they are working, their readings may give an indication as to the problem. Also check your front door switches, if they are bad your laser power values can get screwed up.
          The charge roller contacts inside the drum unit can also be an issue, but you will usually see some kind of banding when that occurs, but it may be worth a look. Check your drum ground also.
          • nobody-here
            • Mar 2008
            • 237
            It looks ok, but I will change for a try.
            Sensor Readings ok,
            COntacts on drum or ground ok
            Front Door Switches? I will check...Why they should cope with laser power?
            • Fearless V K
              • 620
              They are the laser interlock switches, they get dirty and don't provide enough power to the laser unit. There is a bulletin on that.
              • ivacopy
                • Oct 2008
                • 46
                Voltage
                Did you change the developer, charge roller and drum?It might be the reason for the problem because the voltage always increases when the potential of the drum reduces.
                • nobody-here
                  • Mar 2008
                  • 237
                  Here in Italy couldn't find any bulletting for this problem (We don't have tessa access, only local resources)
                  Can you send it to me, I will provide my email on PM!
                  Thanks.
                  • DRORBAR
                    HELLO
                    DO YOU CLEANING DRUM UNIT???....
                    HOW value ID SENSOR?....
                    YOU HAVE PALE COPY?...
                    • nobody-here
                      • Mar 2008
                      • 237
                      Drum unit cleaned, and checked.
                      Pale copy yes.
                      Changed everything.
                      My collegue also told me that he erased nvram.
                      Thanks again!
                      • TonerMunkeh
                        Professional Moron
                        • 3865
                        He flattened the NVram? Did he re-input the non-default values? Aside from that the laser unit has probably given up the ghost, just replace it as a unit.
                        Hit it.
                        • nobody-here
                          • Mar 2008
                          • 237
                          non default values Values where re-input.
                          We are trying to reprogram nvram with original values.
                          What do you mean "given up the ghost" I can't understand-
                          Thanks for your help.
                          Vincenzo
                          • TonerMunkeh
                            Professional Moron
                            • 3865
                            Sorry, I should have realised you wouldn't understand sayings like that lol
                            It may be the laser has gone faulty. I've had really high charge levels been caused by defective laser units before and they've also given SC326 not long after, caused by the same fault. Give that a try too.
                            Hit it.
                            • nobody-here
                              • Mar 2008
                              • 237
                              My english is worsening!
                              I'll need a new training course in London!!!
                              Thanks, I will try a new laser.
                              We put old NVRAM values (we saved the original) and waiting for the results.
                              TX
