Print from USB
+ More Options
Posts
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    #16
    Originally posted by Jomama46
    What is the FAC1 option?
    Glad you asked.
    Tye FACI is the "Fiery Advanced Controller Interface", that allows a monitor, mouse, and keyboard to be attached to the Fiery.
    Without it, those ports do nothing once Windows starts on the RIP.
    (Notice I mentioned Windows - that means that it's not an option for the Linux based RIPs.)
    The FACI is a one-time dongle that actually flashes the BIOS on the motherboard to use the peripherals. Once it's used, it can't be re-used on another Fiery. (When EFI has the Fieries built, the motherboard has a special BIOS which cuts off the peripherals once the OS starts.)
    BTW... another way to scan on quite a few Fieries is to scan to a mailbox on the Fiery, then use Fiery remote Scan or the web interface to retrieve it. You can also set the Fiery to delete the scans after a set period of time (the default is one day.).
    • Dokumaxx15
      • Dec 2010
      • 10
      #17
      RICOH MP C300/400 can do that native --> Print from Media
      www.schoettl.de
      • Mr Spock
        Vulcan Inventor of Death
        • Aug 2006
        • 2064
        #18
        Most newer Konica Minolta's can do it as well. Do not even need the fiery. They do need the hard drive option because it is under the system user box for finding the usb drive.
