Print from USB
  • Jomama46
    • 2900
    Print from USB
    Does anybody know of an MFP that has this capability.
    Ricoh will Scan to USB on the newer color and a couple of BWs but nothing about Print to USB.
    sigpic
    A+; Network +; PDI+
  • sdrawkcab
    Confused & Bewildered
    • Jun 2009
    • 317
    Toshiba's scan to and print from USB in PDF, TIFF, JPEG and XPS formats, not sure about other brands.
    Some days, it's just not worth chewing through the restraints
    • Bani
      • 34
      The Sharp MX Serie Scan to USB and Print from USB.
      • Vulkor
        • Jun 2009
        • 946
        Print FROM USB or TO?
        Any MFP you can USB to a PC. Can't think of any Savin/Ricoh except for a tiny fax aio they sell that can print from say a Thumb Drive.
        • ExOceMan
          • Sep 2009
          • 63
          why would you print to USB? He must mean scan right?
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            The only Ricoh machines that can print from USB are the newer ones with Fierys attached - you use the USB port on the Fiery.
              • 23009
              We're a Copystar & Samsung dealer, and to my knowledge all Copystar, Samsung & HP with an USB port can print to it. =^..^=
              • Jomama46
                • 2900
                Right, I am saying Print from USB.Ricoh has the little "Sammie
                AC207. put in a USB stick and print a file stored on there.
                Richo a little behind in the times here, it looks like. The 207 is only 22cpm and that is the only one AFAIK.
                sigpic
                A+; Network +; PDI+
                  • 23009
                  Ah! Now I get it.
                  The same goes. Any Copystar or Samsung with the USB2 port on the front of the machine can print files from a USB stick. =^..^=
                  • TonerMunkeh
                    Professional Moron
                    • 3865
                    The MPC2550 can do it, you can get an optional USB stick and SD card interface to connect devices to, it uses PictBridge to print them.
                    Hit it.
                    • Jomama46
                      • 2900
                      Problem with using PictBridge is that is requires the camera to trigger the printing and its doesnt support DPOF, so it would print all or nothing. Also I am not sure it will print anything that is not a pix, (jpg, png,etc)
                      sigpic
                      A+; Network +; PDI+
                      • Jomama46
                        • 2900
                        This looks like the solution but it also looks like they took away "scan to usb" with the Fiery.
                        I am looking at the EFI8100 brochure. I think there is a new EFI for the C4000 but cant find anything on it.
                        sigpic
                        A+; Network +; PDI+
                        • KenB
                          Geek Extraordinaire
                          • Dec 2007
                          • 3944
                          The E8100 can scan to USB, although probably not in the way we're thinking.
                          If you have a FACI kit installed in it (optional), you can hook up a keyboard, monitor, and mouse to it. You would then use Fiery Remote Scan to scan to a local file, which in this case, would be the USB. There are 2 USB ports on the front of it.
                          The E5100 (RIP for the C4000) can't do this.
                          • KenB
                            Geek Extraordinaire
                            • Dec 2007
                            • 3944
                            Originally posted by terramobil
                            If you are thinking about using a fiery controller, you can also think about placing an old PC or Laptop near the copier to print from USB Stick. It's not that expensive as to use a fiery.
                            Good point!
                            You can do the same for scanning, as well.
                            The difference is that the Fiery Remote Scan tool can not only load as TWAIN driver, but it's freestanding, too - meaning that you can scan directly to file without having a host application, such as Acrobat or the like,
                            • Jomama46
                              • 2900
                              What is the FAC1 option?
                              sigpic
                              A+; Network +; PDI+
