SC 582
  • mel
    • Aug 2025
    SC 582
    i have a LD 550c that has an SC 582 ihave all the voltages and replaced the fuser relay board can anyone have any ideas
  • limo
    • Jun 2008
    • 103
    Most propable cause is the IH COIL unit (open thermostat).
    You have to replace the unit or reset the thermostat.
    Once i use ice to reset the thermostat without removing the unit.
    Its working fine
    • mel
      thanks for the info
      • neergish
        • 177
        Re: SC 582
        Its working fine
        Hi I know this is from a while ago but could you explain how you did this, im about to launch Im just run into the same issue.
        "See if you can rent a spring hook and a phillips screwdriver it will make your life that much easier..."
        • rsyarcia
          Hair Straightener Tech
          • 711
          Re: SC 582
          on top of the thermostat you can see a black plate. use a needle, slowly insert(the tip of a needle) it under the plate to let it pop up.
          Nobody is perfect..
          • neergish
            • 177
            Re: SC 582
            That worked a treat, thanks, I'm naming my next child after you.
