Ricoh 7500 / Savin 8075
  • mrfuser
    • 1601
    If we do a complete memory clear will it shut off the user account codes so we can get into the machine?
    It asks for a code when you first turn it on and no one knows the code and I can't see it on the service report print out, nor can I find out how to reset it in service mode anywhere in the manual.
    kelly
  • Vulkor
    • Jun 2009
    • 942
    DOOOON"T DO a Full Memory Clear!!
    SP 5846 - 50
    Initialize All Addr Book
    Clears everything (including users codes) in the directory information managed by UCS. However, the accounts and passwords of the system administrators are not deleted.
    Though I think this will still require you to have a user code, though now none would be programmed. You don't know how to get into User Tools and Admin settings to turn off Key Operator?
    • tcs04
      FORMER Techie
      • 1183
      kelly
      ...... Trained Tech????
      As it's an "operator adjustment"
      (From memory)
      Log in as admin
      (User Tools / key button / "admin" as username / (Password not required) / System Setting / Admin tools / next(?)/ address book management / new program / (input name "Change") Auth info / (Input code) / next / input permissions (Copy / print etc) ok...... logout.
      Should give you a new code to use
      If it doesn't work
      Log in as "supervisor"
      Reset the admin login if it's changed
      Login as "admin"
      Disable user code mode In admin settings
      Delete all codes in address book management
      RTFM!!!!!
      • tcs04
        FORMER Techie
        • 1183
        OR!
        if the machine is networked, browse to the I.P of the machine.
        Login (Top Right) as "admin". enter "Address Book" Left of page.
        From here you can print the list of codes and add new ones if required.
        If someone has changed th admin code, use "supervisor" in usertools as above to reset the admin code.
        I repeat... RTFM (If you are trained!)
        • unisys12
          • 490
          why wouldn't you just turn off Authentication?
          sigpic
          The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
          • tcs04
            FORMER Techie
            • 1183
            Don't think they know how!
            (user manual security settings)
            • unisys12
              • 490
              DOH!!
              sigpic
