mapped network drive for smb scanning
  • kayjaig
    • 144
    Have anyone try to use the mapped network drive for smb scanning under the peer to peer networking environment?
    please share your experience. thanks.
  • KenB
    Geek Extraordinaire
    • Dec 2007
    • 3944
    You can't map a drive to scan to with a Ricoh (or most any) MFP.
    SMB works (with most models, anyway...), but you have to use the full UNC path to the desired folder.
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1889
      Ken is correct. You can map it with any drive letter you want, but for SMB you're using the UNC name & folder path. There's not even a need to map it unless it's not on the computer you're on.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
