MP 4000B SC819 issue
  • Alex Novo
    Ricoh MP 4000B/Aficio MP 4000B (code D009-27), serial no. M5482700815.
    I've got a SC-819 and 564d 2069, 7320 66756c error state.
    Copier doesn't hold neither HDD nor any SD or RAM card (surpised a lot).
    So when I try to insert SD with firmware, machine tells "Functional problem detected. Press Restart after the current process. Repeat settings after the machine has restarted.", than after reboot about 5 minutes of booting stops with 878-1 error. I can come into y107r menu and alter several settings, but most of them are "invalid parameter". Settings are not saving. I have downloaded NVRAM contents to SD card successfully. After getting SD out of it - returns old 819 code without any change
    The questions is: do I have to order a new controller board, install hard drive or whatever else? Or I have wrong firmware?
    If anyone who has access to firmwares could send me correct firmware (I don't now what to place in "romdata" and "D009" folder, just try to copy D0095160H.fwu in all of them). My email is alex.a.novo@gmail.com.
  • Sashko
    • Oct 2009
    • 110
    Replace the controller board.
    • Alex Novo
      So i don't have any cheapier way either than buying new CB?
      Don't even try to reload firmware or add HDD/RAM module to eliminate unsufficient RAM?
      BTW I have only Engine firmware, ver. 1.05:05 for D0095160H
      • wwaweru
        • Aug 2009
        • 25
        Hi my name is Walter
        I had the same problem on my MP5000 got another controller Board after i replaced it gave me an SC980 anyone has a clue on how i can sort this out??
        Regards Walter
        • Venom
          Technical/IT Support
          • Nov 2009
          • 765
          Regards Walter
          Are you sure you got SC980?
          IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
          • wwaweru
            • Aug 2009
            • 25
            My apologies guys i mistyped it the error i got was SC998, sorry about that
            • TonerMunkeh
              Professional Moron
              • 3865
              To quote the service manual:
              SC998: A RAM or DIMM option necessary for the application is not installed or not installed correctly.
              Did you order the correct board too? There are a few different types for the MP4000/5000, relating to whether it's got a colour or B&W scanner.
              With regard to the orignal thread topic (before it was hijacked), yes, the controller has had it. As I've said make sure you order the correct one.
              Hit it.
