Mpc - 7500 new printer/scsnner sd card printer not detecting
  • sabah_karim
    • Sep 2009
    • 67
    Hi
    New SD card printer/scanner card not detecting printer option as
    on same m/c with old card everthing is working ok.Detecting
    printer and printing from network and all other normal.
    Is anything to enable printer option in SP mode or over
    network if new SD not detect printer over network.
    sabah
  • sabah_karim
    • Sep 2009
    • 67
    Originally posted by sabah_karim
    Hi
    sabah
    I am again some more tips if i am pinging from m/c it's pinging sucessfully
    and when pinging from PC then also pinging sucessfully.From PC
    printer showing offline because no printer option displaying over display.
    sabah
    • unisys12
      • 490
      Sounds like you have a bad SD card.
      - Print controller is seeing and communicating with network (hince your ping request were returned0
      - Older SD card, used in new MFP. If I have this straight, then you just isolated your problem. SD card is the problem.
      sigpic
      The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
      • sabah_karim
        • Sep 2009
        • 67
        Well old SD is working perfect with MFP.Only new one and that only not detecting
        printer.Of course scanner no problem, scanning ok.
        Is any service SP option to enable over SD card to detect printer.
        • tcs04
          FORMER Techie
          • 1183
          Hi
          sabah
          Why are you changing the card?? Has the old card been copied onto the Postscript card and is the old one in the front door?
          Can you see the printer and scanner functions in the User tools and Sp mode menu screens?
          When you installed the new card, did you disable USB and Printer in SP 5985, reboot the machine, re-enable them then re-boot again? It could be the machine is "Locked" to the previous card.
          Have you updated the firmware? I had a spooky one when I commissioned a new MPC6000, set up the printer / scanner, updated the firmware and the machine lost the scan function! Had to reload older firmware to overcome the problem!
          • sabah_karim
            • Sep 2009
            • 67
            Thanks Tcs04 for replying in ver manner way.It looks like unisys in straight says if good SD is working in m/c
            it's straight SD card is bad.
            In user tools as well in sp mode no printer option displaying.
            Diasbled using sp - 5985 NIC and USB and rebooted m/c then enable again.Problem
            still persist.
            As far firmware updateing is concern my SD is brand new and i didn't updated my firmware
            is the same version 1.07 and old sd working ok.
            sabah
            • tcs04
              FORMER Techie
              • 1183
              still persist.
              sabah
              If the old card is working, why do you need to replace it??
              The new card may have updated information and so may require newer firmware on the machine to interface with it. As I said, I updated the firmware on a new installtion and lost the scanner option, which indicates the IS an issue with the balance between these options and the firmware level.
              There are at least 2 (Engine) upgrades since ver 1.07. If you do upgrade, be careful to read ALL the release notes as there are groups which are installed as a set.
              • tcs04
                FORMER Techie
                • 1183
                still persist.
                sabah
                Just had a thought!
                Are you trying to COPY the application onto a new SD card to avoid buying an option for another machine?!? If so, it won't work!!
                • sabah_karim
                  • Sep 2009
                  • 67
                  Purchase new option printer/scanner kit. Not trying to copy. Atleast on two occassion i stuckup
                  while upgrading firmware.So i am little bit narvous.But after reading all release notes.I will later
                  upgrade firmware. Thanks tcs.
                  • stephend
                    Senior Technician
                    • 306
                    Hi
                    sabah
                    Newest Print/Scanner SD cards will not work if your firmware is not at the latest level. As soon as you will upgrade the firmware of the machine you will have the surprise to see your Print feature on. Scanner is working without the upgrade but Printer does not.
                    Try it and let us know how it worked.
                    • tcs04
                      FORMER Techie
                      • 1183
                      But... As I mentioned earlier, the LATEST firmware may in fact cause this problem!! Ricoh (UK) have a group of firmware on the TESSA (technical ) site for this machine which is downloadable as one file and WILL work, but does not (Or didn't in November) contain the absolute lastest firmware for all groups. I only found this out when I Phoned them having installed the latest levels at install which caused the problem! (So much for upgrading at installation!!)
                      • stephend
                        Senior Technician
                        • 306
                        Engine v15101, Pinter v110 and System v110 worked for us with the the Print/Scanner cards received in October/December. Now for all units received in Jan 2010 the firmware is already installed from the factory.
                        • sabah_karim
                          • Sep 2009
                          • 67
                          warm hello to all
                          my friends done it after upgrading f/w magic works and printer ok now.
                          thanks to all
                          sabah
