Thermostat part number for Savin 4045
  • olsong
    • 24
    Can you help me with the part number for the Savin 4045 fuser thermostat? I find the number (Savin tech site) to be G0654156 and a friend of mine says it is B2984156.
  • olsong
    • 24
    I am told the fuser section could be out of a Savin 8035. Can anyone tell me the part # for the thermostat in this fuser? I show it to again be G0654156.
    • teebee1234
      • Jul 2008
      • 1670
      4045 thermostats - G0654106
      8035 thermostats - G0654156
      • olsong
        • 24
        Teebee1234,
        Have you ever heard of substituting a fuser section? If so how might I determine what I have?
        • zyqwiz
          • Jun 2009
          • 333
          G0654106 - fuses are 5cm apart
          G0654156 - fuses are 1cm apart
          • olsong
            • 24
            Thanks so much, I think this could be the solution. Can you tell me if the G0654156 fuses are not in a direct line but connected slightly offset. If they are offset this is the answer.
            Thanks again.
            • zyqwiz
              • Jun 2009
              • 333
              Yes they are offset
              • olsong
                • 24
                zyqwiz, thanks so much. I have ordered the fuses G0654156 emergency overnight from Savin. I believe this means the fuser section in this machine is actually from a Savin 8045 while the machine it is in is a Savin 4045. I would like to know of a place where I can actually see the part. When I look at the parts list for the 8045 the thermostat (w/fuses) looks the same as the 4045 which has fuses 5cm apart.
                Anyway the new thermostat group will be here in the morning and I will keep my fingers crossed.
                Thanks again, your help is huge.
                • zyqwiz
                  • Jun 2009
                  • 333
                  I have seen both cos I keep them in stock. The parts picture was probably copied across from the old model to the new model by whoever makes the parts catalogue!
                  • olsong
                    • 24
                    You are right!
                    Wow, the replacement thermostats arrived and they fit properly and the machine is at the customers and working fine.
                    Thanks again for your help. Your time here is much appreciated.
