Heeeeelp - Afico 2020 PCU
  • BLADE
    replied
    genuine toner ?
  • zyqwiz
    replied
    One of the busings that holds the charge roller has a metal contact in it with a pip that runs on the end of the charge roller. The pip can come off so that it doesn't make proper contact.
  • Prowag
    Guest replied
    @flo
    Tks for this. This is exactly what was done every time, except for a drum inital, since I don't think it exists for this machine, does it?. I rechecked the Handbook, but it does not say anything about a drum initialisation.?!?
    @anka monki:
    Good Idea. Maybe something with the recycling coil. Can't yet see why the same problem would occur on 3 different PCUs, but if the coil or some other part there has a problem, waste toner sooner or later would be pressed out underneath the blade and make a nice fat black streak.
    Thanks a lot for the input.
    Any other suggestions are still very welcome!
    Ralf K.
  • anka monki
    replied
    sounds like waste removal problem
  • flo
    replied
    First after changing all you have initial the new drum, then initialize the new developer.
    When you change all you also clean mag roller so it is clean,
    At last look at the gears its possible one is defective or not good
  • Prowag
    started a topic Heeeeelp - Afico 2020 PCU
    Hello,
    I got sort of a weird problem on the PCU Type 2015 (used in a 2020 in this case) with one customer and I feel I need some help, input or ideas.
    Refit is done by the book. Developer type 28, charge roller, charge roller cleaning roller, drum and balde renewed. Powder applied to blade and drum.
    PCU is installed in customers machine and between 10 to 20 working days later the customer calls and has a grey to black streak on the lower end of the printed page. It is between 2 and 4 cm high.
    The drum on the back end of the PCU is black too and the surface looks pretty worn. Under the balde you have toner accumulation. The drum is rubbish and so is the blade.
    We did that now 4 times with 3 DIFFERENT PCUs and it just happened again - today, 7 working days later, the customer calls it. For this last PCU I got a colleague to do the refit, because I did not trust myself anymore..... Talked to Ricoh as well, but no avail.
    Ricoh is not our main business, but I did a few of these PCUs for other customers too and never heard anything back. What am I doing wrong?
    We are wasting drums, baldes and other parts on this one machine and I am looking for someone to give me an idea, hint, tip or best case: a solution to this problem.
    So, please... anyone experienced with the type 2015 pcu having good ideas, pleeeeaaaase help
    Kind regards
    Ralf K.
