Ricoh 3025/SR 790
  • TECH BOY
    • Nov 2009
    • 63
    Ricoh 3025/SR 790
    Hi All,
    This thing is kicking my butt !!!I have a Ricoh 3025/ SR 790 with constant jamming problems.This only happens when stapling.I have replaced all rollers the whole finisher along with the bridge unit...nothing helps.I notice that the paper comes out quite curled (when it doesn't jam).I brought some expensive paper over to try and it seemed good.Can this be a combanation of cheap paper and a long paper path???they have many other Ricoh's with no problems 2020 2060 etc.Does this model/finisher need premium paper??Any help would be great.
    Thanks,
    Tech Boy
  • copyaction
    • Oct 2007
    • 991
    since you mentioned the curl, have you tried replacing the fuser or at least the press roller?
    • CANCOUNTRY TECH
      • Aug 2008
      • 114
      my money is with copyaction here.Very common in ricoh mpc2500-5000 the pressure is uneven and due to the paper path finisher jams are common.Rebuild the fuser your problem will be solved.
      • zed255
        How'd ya manage that?
        • 1024
        The very last paper guide in the finisher, the upper one, before the staple tray has a nasty ridge in it. I've found removing the guide and filing it smooth goes a long way to improving the finisher's performance. Also apply a little silicone oil to the inside of the jogger guides (just a little on a cloth or cotton pad and wipe it down). The premium paper does help, but most clients won't see it that way. It's a case of "Your POS finisher should take whatever paper I feed it!" usually.
        • TECH BOY
          • Nov 2009
          • 63
          Thanks for the responses,Yes The machine has a new fuser unit.Both rollers were replaced.Does anyone know if the fuser temp can be ajusted?would this be a good idea?Thanks again for your time.
          Tech Boy
          • Koosie
            • Nov 2008
            • 121
            Adjusting the fuser temperature is not the way to solve the problem. There was a thread about this : http://www.copytechnet.com/forums/ri...em-staple.html
            • TECH BOY
              • Nov 2009
              • 63
              I have tried sanding down the guide (which did have ridges). It seems to be good for now.My question is ,if this does not work is there a finisher ( not SR 790 )with less issues that will work with a Ricoh 3025?
              Thanks agian,
              Tech Boy
              • zed255
                • 1024
                Not really. There is a crappy 500 sheet unit that some have had issues with (I only have a few machines with that one so I can't say, but I did have one with repeat stapler drive problems). The guide sanding, silicone oiling (very lightly to prevent static), and sometimes a slight loosening of the drive belts in the back have all helped me. If the customer is willing to switch up to a higher quality paper, in addition to the mods, the issue will usually abate.
                Last edited by zed255; 01-27-2010, 04:06 AM. Reason: Spelling - Really old laptop with a few keys that work poorly.
                • ucinn
                  • Jun 2009
                  • 383
                  I have one that I sanded, did the update mylar pieces and it still was jamming intermittently with curly paper. I finally removed those white flappy things at the end of the guide before it goes into the finisher and haven't heard back from them for a couple months now. I don't know what they are for, but seemed to be causing the problems.
                  • TECH BOY
                    • Nov 2009
                    • 63
                    Thanks for the update.I am not sure what white flaps you are referring to.The bridge unit is before the finisher,are the flaps on the bridge unit???Let me know if you can explain in detail.
                    Thanks again,
                    Tech Boy
                    • Ralph S
                      Does it only happen with papper loaded in the long edge feed direction? Does it happen to 14" and 17 " paper? I have had cheap paper work, but the grain of the paper needs to be perpendicular to the paper travel. Then there should be less curl.
                      • TECH BOY
                        • Nov 2009
                        • 63
                        They are running it short edge and they only use letter size.This is why I want to try a SR 820.It has a straight paper path but I don't have any experience with it.Most of the jams are happening when the paper is being loaded into the staple section,they just curl around into a ball.I thought Ricoh would of thought of a better design....too many turns!!
                        Thanks ,
                        Tech Boy
                        • Ralph S
                          The link above here seems to have some good info. Have you tried some of the sanding of the guides and the slight bending that one of the threads suggested?
                          • TECH BOY
                            • Nov 2009
                            • 63
                            I have done the sanding and forming and it does seem better but not great....
                            • ucinn
                              • Jun 2009
                              • 383
                              Thanks again,
                              Tech Boy
                              No, they are in the sorter, they are on the spring loaded gate right at the exit to staple tray. If you watch it run with the sorter door defeated, right when the paper is entering the staple tray, you will see four white things raise up and then drop once the trailing edge leaves them. I hope this explains it well enough, if not let me know and I'll look them up in the parts diagram and get the official name of them.
