Toner drop inside the machine from transfer belt connection to the toner collection i
  • aaahmmm
    • Aug 2009
    • 103
    lot Toner drop inside the machine from transfer belt connection to the toner collection in aficio 1060
    I have aficio 1060,i find a lot of toner inside the machine ( mostly on the rear of the duplex) I find that its drop from the transfer belt its waste toner ,I remove the transfer unit and clean every thing and check the transfer belt waste toner coil and the toner collection coil from transfer side its ok and moving,I install the unit .
  • unisys12
    • 489
    From the back of the machine, check the reclaim coil assy. There is one screw that holds it in and if over tightened, it will tilt back away from the frame. This will allow any waste toner, moving from the transfer unit into the coil, to fall out. After removing the rear cover, you will see a pile of toner under here as well.
    sigpic
    The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
