Dsc 428 Black Dev Unit
  • CrapAimer
    • 296
    Put a new Black Dev unit into machine two days ago, same fault has occured blank patches, as if dev burnt out. ???
  • teebee1234
    • 1670
    Sounds like the developer clutch needs to be replaced. Pretty common, clutch doesn't release and the developer gets depleted in no time. Part #AX200273
    • Ricohslave
      • 27
      +1 on that.
      Check for diagonal bands in solid areas and if dev unit feels very light, definately faulty clutch
      • freginold
        • Sep 2010
        • 102
        Yup, we have those clutches go bad on older machines all the time. Put a new black DV unit when you replace the clutch as well.
        Config page instructions for copiers, printers, & fax machines
