Athena and Apollon Charge Rollers
this may work on these machines what i do on mpc2800 etc is clean all the coating off the charge roller back to a cream/ white surface then refit and away you go i know it sounds mad but try it on an old unit. normally i will only do this on drum units that fail early this will workComment
PPC england do a rebuild kit for 58 euro ( very handy 20 mins ) they also do a re-man kit ready to go for 80 or new at 110sigpicComment
Hey Masterchief, who are PPC, I have searched and cant find them (Im in australia). Does the kit contain a new charge roller? Can you post a link to the PPC Site. Cheers from Aus1Comment
Kinda like to know where I could get those charge rollers from, too, like a bunch of us.NEVER ASSUME ANYTHINGComment
I think I found this PPC mob @ Compatible Printer and Copier Consumables | Canon | Ricoh | PPC Solutions Ltd but be buggered if I can find these charge rollers. Im in Aus too so I doubt I could get them if I wanted.I have not failed. I've just found 10,000 ways that won't work. ~Thomas EdisonComment
Ricoh MP C2500 OPC Drum Replacement Kit | MP C2000, MP C2500, MP C3500, MP C4500
looks like the thing we could be looking for. has anyone been using anything like this? do they last? How much do they cost?
cheersComment
I use some PPC products (for use in Ricoh m/c's) and they are very reliable!
Drum B070-9510 lasts for more than 700K copies, hot and pressure rollers for AF-700 and AF-1075 are similar to the OEM, i could say just the same! And very cheep...
I buy them from a retailler and i will try to get one MP C-2500 Drum kit .
My two cents to Aussie's friends!!Comment
I look forward to hearing about your results. I have forwarded this info on to my manager to see if we can try these units. Please let us know if you find out any info regarding purchasing just the charge roller.
CheersComment
Re: Athena and Apollon Charge Rollers
The charge rollers normally clean up pretty well to stretch the yield on these bad boys to 100k or so, depending on coverage of course. Unfortunately there are no charge rollers available from Ricoh.
Have you tried using black PCUs instead of colour? I've heard that this can be done, but I'd ever do anything like that!Comment
The black PCU can only be used in the colour bay on the MPC4500 range. The newer models have different wiring, and you will get a message telling you to insert the pcu unit correctly. To fit a black unit to the colour bay, you need to file down the rear connector block to make it fit. The champher is on the opposite side. You file the side with the metal pin to the same angle prior to fitting.
lol you have alot to learn if you think thats all the 2042 will fit.....
i use them on everything i have including 01 seriesComment
