MPC2050 - Internal Finisher issues
  • huberto233
    • Nov 2008
    • 40
    Well known problem with plenty of them out there. First of all , the shaft which a stapling unit moves on is not lubricated-greased on production line . So what needs to be done to get it working just lubricate the shaft and problem disappears. I have had to do at least 5 and all of them ok since.
    Another common problem on the paper exit section , check the timing pulley (section 10 part 8 ) as in plenty of machines one of them is installed upside down , mostly the front one. As u may see on parts catalog they should be in the same position.
    Network+,
    • mrwho
      Major Asshole!
      • 4299
      As for the lubrication on the stapler's shaft, I've been doing that since the first time I got this problem - even before posting on this forum. About the pulleys, by looking at them it seems that everything is in place - the belts rotate accordingly and I see no apparent anomalous movement, so I'm assuming everything is in place - I'd like to ask you if it's obvious when they are misplaced?
      Mascan42
      Ibid
      • huberto233
        • Nov 2008
        • 40
        Yes, there is quite obvious if the front one is misplaced. Chec a parts catalog - section 10 and you should see the proper direction of install
        Network+,
        • mrwho
          Major Asshole!
          • 4299
          #19
          Well, if you ever catch another one like that, please try and take a picture to illustrate it, if possible.
          Cheers!
          Mascan42
          Ibid
          • huberto233
            • Nov 2008
            • 40
            #20
            Hope this will help
            Network+,
            • Fearless V K
              • 620
              #21
              Originally posted by Jomama46
              I'm not seeing anything since 10/08. V 0.039 "D". Any other info on that?
              No, I think that was it. Here's the doc...
              Don't take that toner with me!
              • mrwho
                Major Asshole!
                • 4299
                #22
                It does - I was thinking it was another set of wheels altogether. I'll check it out today.
                I'll keep you posted. Thanks.
                Mascan42
                Ibid
                • Jomama46
                  • 2900
                  #23
                  Thanks Fearless, this is helpful.
                  sigpic
                  A+; Network +; PDI+
