Headache with Savin 3335
  • vonhetcchtel
    • 42
    I am having reoccurring error SC 541 and 542 with my customers Savin 2535
    Pleae Help
    Last edited by vonhetcchtel; 02-05-2010, 10:38 AM. Reason: I gave a Wrong mark before
  • Vulkor
    • Jun 2009
    • 946
    Thermistors, Thermostat (or does this old one use Thermofuse)?
    • Llama God
      • Mar 2009
      • 1353
      Or the hot roller. Or, as an outside guess, the connector block on the back of the machine where the fuser plugs in
      • Vulkor
        • Jun 2009
        • 946
        Yep Worn Hotroller, true, I just rarely have that happen since maintenance occurs usually enough. If it doesn't we do Courtesy Calls on customers who don't call in enough.
        As for the Fuser Plug. What a PAIN!, but I've seen it 2x in past 4 years.
        • Llama God
          • Mar 2009
          • 1353
          But you never know how closely the PM schedule is followed, do you?!!
          • Vulkor
            • Jun 2009
            • 946
            If you put when a PM is done on the Paperwork, and the Secretary enters that in the Field E-Automate will let you know when the Next PM is due. We keep digital and manual paperwork on all work that is done.
            • Fearless V K
              • 620
              We use E-Automate too. Good program.
              Don't take that toner with me!
              • Vulkor
                • Jun 2009
                • 946
                Only as Good as the User
                • Llama God
                  • Mar 2009
                  • 1353
                  I meant on this particular machine, but I agree with your point as we have similar systems
                  • tcs04
                    FORMER Techie
                    • 1183
                    Pleae Help
                    Try changing the double ended connectors the thermistors plug into (Red connectors clipped to the frame). These can deteriorate and cause misdetections.
                    • ender
                      Ender
                      • Mar 2009
                      • 13
                      I agree with tcs04. Thermistors are always heating and cooling. bad connection.
