Lanier vs Ricoh firmwares - Are they the same?
  • mrwho
    Major Asshole!
    • 4299
    I'm servicing a Lanier LD090 and I'll probably need to reflash it. I've got access to Ricoh firmwares, but I don't have to Lanier ones - are they the same?
    Mascan42
    Ibid
  • iMind
    Vacuum Cleaning Expert
    • Mar 2008
    • 1116
    No problem, the hardware is all the same. Ex: a "B247" will be the same under any brand name.
    sigpicWe can all Win, but at the end we all loose. Save the greyhound
    • mrwho
      Major Asshole!
      • 4299
      Thanks!
      Mascan42
      Ibid
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        Makes it easier on the engineers that way.
        • mrwho
          Major Asshole!
          • 4299
          Well, just updated this Lanier LD090 with Ricoh firmwares and now all I get is an error SC990 (along with an SC870 in the log). Reflashed everything, formatted HD, downloaded stamp data, all without avail.
          Before updating the firmware, the machine didn't present any error.
          Any clues?
          Thanks.
          Mascan42
          Ibid
          • iMind
            • Mar 2008
            • 1116
            Did you read the release notes, when System firmware update is done you must update BIOS\NIC\LCDC as a set.
            • mrwho
              Major Asshole!
              • 4299
              My fault.
              When downloading the firmware, I downloaded the versions at the top of the page, assuming they were the most recent ones. As someone's sig on the forum says, "Don't assume assume anything". The firmwares weren't sorted by version, so I ended updating the machine with firmwares that weren't the latest ones.
              As soon as I rectified it, all was okay. Thank you all for your time!
              Mascan42
              Ibid
              • iMind
                • Mar 2008
                • 1116
                Originally posted by mrwho
                My fault.
                for the feedback.
