Ricoh Aficio 2228C documents
  • copyguy1642
    • 22
    Does anybody know if it is possible to retrieve the documents from the document server on an aficio 2228C? Are the PDF or a proprietary format.
  • pLatik
    • 169
    in the web admin, you can retrieve the documents in the format of PDF and JPEG
    • copyguy1642
      • 22
      I am trying to practice this on a Ricoh aficio 1224C, but do not see files or where they might be. I went to web address of copier & logged in with admin & password. Is this the same as aficio 2228C or am I doing something wrong?
      • Venom
        Technical/IT Support
        • Nov 2009
        • 765
        You need the file format convertor option to retrieve from the doc server to a pc. The 1224 is a bit different as well because you can't copy address book but 2228c you can.
        IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
