I am tring to fix the Ricoh Aficio 1045 Copier. The Error Code is SC541, Thermistor Open. I am assuming if I replace the two thermistors that I will be back in business. First question is, when I test the see which one is causing the problem, what should the resistance be for the thermistors and where are they located for the Ricoh's copy machines. Thanks for the help
