Hi! I just want to ask about the charge roller blade of Aficio 2035/2045. We have some case here that everytime we check the PCU especially when we try to clean the cleaning blade, drum or the PCU itself after we assemble it and run the machine, the black lines appear now which comes from the charge roller blade. What seems to be the problem? Is the charge blade that sensitive? Is there a way to prevent the lines from appearing? How often should we replace the charge roller blade? Thank You Very Much!
