Aficio-1045
  • Copier Systems
    • May 2025
    Aficio-1045
    Working on aficio 1045 code sc-322 is there a test in diag. to deterime what comp on laser unit is def.also code 302 charge corona not coming on. removed an cleaned laser unit.
    Was told def door switches will cause sim problem help help want to do a ram-clear but need some help on codes before i proceed. Andy H>Do any one have alaser unit for this box.
  • ganc67
    • Jun 2007
    • 18
    It is usually the polygon motor
    And can go as far as bicu but I would replace the polygon first
    Do you hear a loead pitch sound when running?
    • Copier Systems
      Aficio 1045
      THERE is not a high pitch sound comming from laser I understand the noise you are talking about. Cleaned laser to no avail.Does anyone have
      a used laser unit to use as test.Will get a exchange one if it dosent give me another major.
      Thanks Andy H AAAHopkins@aol.com
      • unisys12
        • 490
        Have you tried doing the laser pitch adjustment? SP2109?
        If not, then I would be happy to send you the info on this adjustment. Just hit me up by PM! We had a tech the other day that had this code and was able to clear it by doing this.
        sigpic
        The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
        • jctech
          • Oct 2008
          • 13
          Laser drive units are conected to the bicu board through a microswitch on the upper right cover, verify the flat cable that conects the ld drive to the bicu and finally verify the ldd unit if it is dusty, it usually is, clean to perfection! then turn on the machine and run sp2109 400dpi and 600dpi. this should do the trick
          Information is meant to shared not sold!!!!
