Working on aficio 1045 code sc-322 is there a test in diag. to deterime what comp on laser unit is def.also code 302 charge corona not coming on. removed an cleaned laser unit.
Was told def door switches will cause sim problem help help want to do a ram-clear but need some help on codes before i proceed. Andy H>Do any one have alaser unit for this box.
THERE is not a high pitch sound comming from laser I understand the noise you are talking about. Cleaned laser to no avail.Does anyone have
