MP2000, scanning issue
+ More Options
Posts
  • aabarnes1
    • Mar 2009
    • 620
    Has anybody set one of these up to scan to folder (smb) on a pc using xp. i have done hundreds of MP5500 and 6000's but this fucker wont connect, any help, thanks in anticipation
    Grant me the serenity to accept the things I cannot change.
  • Jomama46
    • 2900
    Not a MP2000L I hope, it is TWAIN only. oops.
    sigpic
    A+; Network +; PDI+
    • aabarnes1
      • Mar 2009
      • 620
      No, it,s the standard MP2000,
      • Jomama46
        • 2900
        What is the error?
        sigpic
        A+; Network +; PDI+
        • aabarnes1
          • Mar 2009
          • 620
          The error is no connection when I do a comm test. have put the correct path, user and password in WIM, but it just wont connect. Checked firewalland antivirus-all ok
          • Jomama46
            • 2900
            Sounds like either authentication or a blocking program like Norton or Macafee. Did you turn them all the way off? to test the un and pw, try to logon to the workstation using those credentials.
            To check the path, copy and paste it into a Start>Run box.
            sigpic
            A+; Network +; PDI+
            • aaalexxx
              Engineer
              • Jul 2009
              • 51
              are you able to browse into the PC?
              got prompt you for login user name and password?
              • Prodigal Son
                • Mar 2009
                • 161
                I've got the same issue on an MPC2800 at the moment. I've also set up hundreds of MP's and MPC's but this one just won't connect even though everything is fine. Maybe we can help each other...
                What operating system is it on the server / computer you're trying to connect to? Mine's win2008srv, maybe there's a pattern there?
                I'm actually able to browse the network and see all the computers within it, but as soon as I try to browse into the server it fails, even though I've input the correct username. I've even tried the admin-account but it still fails. Is anything of that similar to your setup?
                Peace sells, but who's buying?
                • aaalexxx
                  Engineer
                  • Jul 2009
                  • 51
                  have u try using IP address? able to browse?
                  able to browse from pc to pc via hostname/ip address?
                  make sure you can browse into the pc/server via hostname and ip address.
                  what do you guys by connect?
                  on the machine are you able to browse into the pc where you will be prompt for login name/password?
                  • homer
                    • Nov 2009
                    • 18
                    scanning
                    If you can browse to the computer, try using fully qualified names. i.e USERNAME@DOMAINNAME or USERNAME.DOMAINNAME. If you cannot browse you might have the wrong computer name you can test that by replacing the computername with IP address. Also NETBIOS over TCP\IP has to be enabled on scan destination computer.
                    • homer
                      • Nov 2009
                      • 18
                      When I said fully qualified name I mean for login.
                      • homer
                        • Nov 2009
                        • 18
                        \\192.168.1.10\scanfolder as an example
