Savin scan to folder
  • Appleseed
    I have a client that has a Savin 8025ep with scan and fax. They are trying to scan to folder by searching their server through the scanner function. They are able to go to their server and see folder names but the names are alphabetical and only go up to "C" Is there a way to get this to view everything on the server or are we stuck the way er are?
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    If I remember correctly there is a limitation of only being able to display 100 directories per directory root when browsing shares via the machine.
    You can still manually input the SMB destination path of coarse (best done using the web interface, then you can copy & paste).
    Example
    //SERVERNAME/USERFILES/B
    //SERVERNAME/USERFILES/B/Bill Smith
    etc.
