savin2535
  • cliffhangers
    • Feb 2010
    • 243
    savin2535
  • johnny32
    • Oct 2007
    • 102
    just a thought but have you checked the thermostats
    • mikadonovan
      • May 2008
      • 2931
      Are you getting any SC codes? Is the machine not fusing properly? Check SP 1106-1 and 1106-2. What's the actual temperature. Actually, what IS the specific problem other than you can't see your hiter shining? Need a little more info to help.
      NEVER ASSUME ANYTHING
      • cliffhangers
        • Feb 2010
        • 243
        savin2535
        it display erro code 541 please help
        • mikadonovan
          • May 2008
          • 2931
          As johnny32 suggested, you need to check the continuity of the thermostats. The email you sent me mentioned SC codes 141 and 142. This model does not have those SC codes.
