Ricoh Aficio 400 SC401
  • tcypy1961
    • 773
    The machine has this code on it and I have already replaced the high voltage circuit board, the positioning belt sensor with the clutch, and the transfer belt assembly complete to solve the issue of the SC401. The only thing I have left to change is the BICU circuit board. If this doesn't solve the problem does anyone have any thoughts as to what could fix this problem? Any hep appreciated, thank you.
  • muaazgujjar
    • 67
    Try to resold the power supply.There must be some doubtful solderings
    • schooltech
      School District Tech
      • Jun 2008
      • 504
      firmware
      Bachelor of Science in Information Technology, Comptia A+, Comptia Network+
      • TonerMunkeh
        Professional Moron
        • 3865
        There is an RTB (10) for this issue, text copied below:
        We would like to inform the history of the ROM modifications for the BCU Board (P/N: A1335104) for your reference. Suffix E of ROM was used from the January 1997 to the May 1997 production. The problem arose after the modification from Suffix F to G for the ROM, but this was not installed in any machines.
        Suffix H is used from the June 1997 production run.
        Problem:
        If the number of copies in one job is large, the copy becomes lighter and SC401
        occurs.
        Countermeasure:
        When the feedback voltage for the transfer belt power pack exceeds the standard voltage, the power pack monitor counter records the occurrence. When the number of occurrences reaches 8, SC401 occurs. The counter resets at the end of each job but it may reach 8 during longer copy runs. Due to this modification, the counter will now reset after each copy.
        Looks like it's going to be a new BICU board. Get the customer another machine sold too, what an old shed it must be!
        Hit it.
          • 23009
          Per Goose's:
          transfer belt lift clutch
          BCU ROM with level (H) or higher (A133 5104)
          drum
          transfer belt position sensor
          The lift clutch is my personal favorite from this list. =^..^=
          • _Brent_
            • Jul 2009
            • 39
            Sounds like a short of the high voltage bias. I think there is a metal roller (in the transfer unit) which should be coated with a non-conductive material, sometimes black in color. Check to see if this roller has any of the non-conductive materials worn which would expose the bare metal and thus cause a short of the bias.
            • Jomama46
              • 2900
              As I recall, pinholes in the xfer belt can cause this too.
              sigpic
              A+; Network +; PDI+
