Ricoh Aficio 240w
  • The-Peanut
    • Aug 2006
    • 192
    Ricoh Aficio 240w
    i have an issue with a 240w
    i'm getting black banding marks on random places all over a print
    the marks seam to be applied from the dev unit, like as if its a charge/earthing issue,
    the best way i can discribe the marks as if i'd brushed toner onto the drum in patches
    i've replaced the dev,
    the drum is recent and so is the cleaning blade, transfer corona has also been replaced
    all earthing and points have been cleaned, including the 1 on the end of the dev unit, with conductive grease also applied.
    i'm going to try the primary (charge) corona next
    any1 came accross this b4?
    cheers
  • zed255
    How'd ya manage that?
    • 1024
    The main charge is the likely suspect. The grid and wire can get really dirty on these and keeping them clean is important. Do you also get or have seen logged any SC30x codes? If charge related SC's are logged then you can be even more certain.
    • mtech
      • Mar 2007
      • 307
      Definately primary carona.
      • The-Peanut
        • Aug 2006
        • 192
        hi
        cheers for info, it was the primary corona,
        cheers
