MP6001 "Dead"
  • tcs04
    FORMER Techie
    • 1183
    MP6001 "Dead"
    Any problems with completely dead machine?
    No op panel / power indicators
    No led indication on either PSU (Main or CTL)... Main PSU has been replaced(!)
    BUT burnt bank of resistors on CTL PSU (Part on order)
    All mains supply ok to PSUs.
    NO outputs from either PSU.
    NO 5v supply to BCU
    Tested with all trays pulled out, PFB power unplugged, all outputs removed from main PSU (Still no 5v, 12v, 24v, 32v leds on psu)
    Ideas??
  • TonerMunkeh
    Professional Moron
    • 3865
    Has the mains cable been squished at any point? Might be there's a break on the insulation somewhere. Fit a new cable at the same time as the CTL PSU. Must have been one hell of a bang to take that PSU out. Might be an idea to order a new main PSU to keep on standby.
    Hit it.
    • tcs04
      FORMER Techie
      • 1183
      Mains cable seems OK. One of the guys ordered and replaced the main PSU. Still dead. The mains is OK at all points required on both the main PSU and input to the CTL PSU. One of each now on (Re) order.
      • spaceman99
        • Jul 2009
        • 174
        I had this and changed both main PSU and CTL PSU. Check fuse on CTL PSU as this was blown.
        good luck
        • tcs04
          FORMER Techie
          • 1183
          good luck
          Fixed! Found burnt resistors on the CTL PSU, Fitted replacement today, all functions normal!
          Thanks for the ideas spaceman.
          • tcs04
            FORMER Techie
            • 1183
            good luck
            Do you think the main PSU "Took out" the CTL PSU??
            • spaceman99
              • Jul 2009
              • 174
              think so.
              Does not appear to much in front of the fuse to pop it. I suspect the main PSU is the bad guy.
              Good luck
              nice 1 :-)))
              • tcs04
                FORMER Techie
                • 1183
                think so.
                Good luck
                nice 1 :-)))
                All fuses on both PSUs were ok.
                M/c still working fine now!
