Ricoh SPc232sf and a counter unit interface
  • thecopyguru
    Can this copier be foreseen with a coin vendor interface / optional counter unit?
    Who is the real manufacturer of this device? Samsung?
  • teebee1234
    • 1670
    Brother makes this one. I've never heard of vending device on this model, but it could be possible to put a counter on it that captures the change in state of the exit sensor. You'll probably have to check with the manufacturers of the devices to see what is possible.
    • msaeger
      • Sep 2008
      • 333
      I don't think one of these would be good for a coin op anyway too hard to operate.
      • thecopyguru
        Neither do I like to put a coin op on it, it's just the customer of a dealer (library) who wants to do so.
        And I only want to know whether it is physically possible (is there a connector and a dedicated mode for it) or would it mean to cut wires to force the "solution'
        • mrwho
          Major Asshole!
          • 4299
          On the old Konicas that didn't allow for an external keycounter, we used to hack it into one of the paper passage sensors, as teebee1234 said - the machine would display a jam if there was no card attached and, when copying with a card, the sensor would provide the needed info for the copies to be accounted.
          Now, if you're going that way, I'd advise you to try it first on your own before giving an answer to the customer. Some other way - probably the best one - would be "No, sorry. Only the more expensive models allow that."
          Mascan42
          Ibid
