fax forwarding to multiple users
  • ferastec
    • Jun 2009
    • 107
    Hi Guys
    Any one can help me on fax forwarding to multiple users for MPC3000, for example
    If I dial fax number+sub(A) code then the fax will be forwarded to user (A) mail box, and dial fax number+sub(B) code then the fax will be forwarded to user (B) mail box.
    thanks
  • GhostInTheMachine
    • Feb 2010
    • 88
    Unfortunately Ricoh mfps won't even let you forward to different destinations if you have 2 incoming fax lines. So I'm sure trying to do it with one is out of the question. At least without some type of 3rd party software or a firmware fix.
    • Vulkor
      • Jun 2009
      • 946
      Think you can forward to a Folder and An Email.. I THINK.. but not two says two email addresses.
      • unisys12
        • 489
        I've done this before, but it was a yr or two ago. I think you assign the "sub code" to the address book entry of the receiver. So if you have user A's email set-up, you go into their address book entry and assign their sub code to them there. I just don't remember if it's done under the User Auth tab or the Fax tab. You might be able to check the operator manual to make sure, but I know you can do it.
        sigpic
        The first law states that energy is conserved: The change in the internal energy is equal to the amount added by heating minus the amount lost by doing work on the environment.
        • Ricoh-ono
          • 338
          This was in the fax users guide.
          Do what you can, with what you have, where you are. ~Theodore Roosevelt
          • ferastec
            • Jun 2009
            • 107
            hi guys
            i have tried it already, but no Success, maybe I have done something wrong.
            Can you assist me how to do it step by step.
            thanks in advance
            • ferastec
              • Jun 2009
              • 107
              hi guys
              i have done it and it works fine, the issue before that i was using lan fax and the sub code is not supported in the lan fax.
              thanks
              • Vulkor
                • Jun 2009
                • 946
                Thanks for info
                • aaalexxx
                  Engineer
                  • Jul 2009
                  • 51
                  global scan nx will be able to let you forward to 2 different destinations.
                  • aaalexxx
                    Engineer
                    • Jul 2009
                    • 51
                    you can only forward to folder or email only. or a group of email address or group of folders.
                    if you want forward to email & folder. can consider forward to email together with auto doc link.
                    • ferastec
                      • Jun 2009
                      • 107
                      hi guys
                      do you think most of the fax machines is having SUB code services? like brother, panasonic, HP extra.....?
                      • richiewhite
                        Forward to a group instead of a single email address
                        Ask the IT administrator to create a email group and add emails of the multiple users that want the faxes to that group
                        Then just fax forward to the group email address on the copier
