Ricoh 2075/Savin 4075 feed units.
  • PhilinFla
    • Aug 2008
    • 13
    After developer has leaked into the feed units has anyone had any success in refurbing the feed units? We have replaced all the one-way bearings but always end up installing new units. This is has been the case in several machines, are we missing something?
  • RicohTech4U
    • Jun 2008
    • 2
    First you need to repair the developer unit to stop future leaks. Also vacuume all leaked DV. Before replacing the one-way gears, scrub the shafts with green scrub pads. Replace the one way gear at end of feed roller shaft (has a spring attached to it). That should do the trick!
    • Fearless V K
      • 620
      Yeah, pretty much need to completely disassemble the units and thoroughly clean all bushings and roller shafts of developer besides replacing the one-ways.
      Don't take that toner with me!
      • PhilinFla
        • Aug 2008
        • 13
        Took apart gears and cleaned as suggested, improved but no fixed - new 1 ways came in this a.m, replaced all the 1 ways and it now works like it is supposed to. Not sure if it was this on site but someone mentioned replacing dev units at 1 Million, we have started to do this to prevent the dev leakage and the headaches of trying to clean up the machine. Thank you both for the input.
        Phil
        • cobiray
          Passing Duplication Xpert
          • Mar 2008
          • 1199
          Usually with a good cleaning and new 1-ways you can refurb the units. We are currently replacing all the bushings in the dev units at 1million clicks or at the 3rd pm, which ever comes first.
          • zyqwiz
            • Jun 2009
            • 333
            If changing the one way gears doesn't fix them - forget it and just buy a new unit
            • nmilisic
              • Mar 2009
              • 30
              Feed units
              I have this problem and here is solution if you do not wont to buy new one way gears:
              First you need to repair the developer unit to stop future leaks(replace bushing 4 big and 2 small). Also vacuume all leaked DV.
              All one way gears from feed units put in oil(diesel) during the night and after that they will work find.
              I know that is dirty job but works perfect.
