aficio 3245c
  • zoul
    • Jun 2025
    aficio 3245c
    hi..
    i've bought this machine as a used unit from my local dealer,but now i can't change timer setting because it will show 'you do not have the privileges to use this function' message..what should i do??
    thanks in advance...
  • cobiray
    Passing Duplication Xpert
    • Mar 2008
    • 1199
    When you press user tools there should be a login button on the touch panel next to the exit button on the top. Try admin an leave the password blank. If that doesn't work you'll need to call the dealer to get the code or turn the function off.
    • zoul
      ok,i've tried it,and it works!!thanks cobiray..
