ricoh 2035 add toner
  • trojan
    • Jul 2025
    Ricoh 2035 please tell me what the problem is that the machine constantly looking for toner, copies of the pale when otvotim and close the lid and the machine begins to spin and stop, but a copy was very faint, then enter the service mode and let forsed toner and get a good copy of the al , And then re-machine slowly starts to loose toner. When you start copying slowly start to lose quality up and starts to fade and to seek toner. The new drum and new developer inside.thanks
  • cobiray
    Passing Duplication Xpert
    • Mar 2008
    • 1199
    Check the mylars inside the toner bottle holder. They often fall off and cause light copies.
    • bob scheffer
      • Mar 2010
      • 27
      Replace toner supply (part # B0823208) or the internal part with the mylars (part # A2323240) which is even cheaper!
      • neocozhu
        • Mar 2009
        • 72
        i suggest that , open the developer lid(in the from), u will see 3 gears , watch them thay will run ?
        • angelark
          toner hopper
          lookslike your problem is with the toner hopper.
          replase A267-3560, G020-3334, A184-3420.
          and your hopper will be new.
          • TonerMunkeh
            Professional Moron
            • 3865
            If forced toner brings the CQ back up, I wouldn't say it's the toner hopper mylars, because it wouldn't add toner at all. What readings are you getting from the TD and ID sensors? Check and post back.
            Hit it.
            • jondrei2007
              sir I'm having same situation of add toner indication, i just replace a toner hopper
              and it indicates again, i try also the sp mode force tonner because copy is light
              but indicates add toner, what are the actions that im going to do sir
              • jonhiker
                • 661
                check your readings of Vsg & Vsp. they should be about 4.0 and .30, respectively( like TonerMunkeh said). You are probably looking at neeeding to replace the TD sensor, which is located on the bottom of the developer unit.
                • angelark
                  try to open the front cover of the cartridg
                  try to open the front cover of the cartridg,
                  do a vacume in this saction.
                  after that the machin will start working.
                  good day
                  • Iowatech
                    Not a service manager
                    • 3930
                    If it is a problem with the mylars, and you can find at least three of them, attach them with screws like the ones left over from changing the PCUs on the Lanier LD435c.
                    Life is rough out here in the periphery, and sometimes we have to make do with what we have.
                    • mannaro75
                      • Apr 2011
                      • 14
                      change the dev
