Using desktopbinder to download scaned documents
  • allan
    RTFM!!
    • 5462
    i am trying to use desktopbinder to download scanned documents from the document server. if i try to save the document the program tells me that require a option to transfer data to and from the machine,
    is this a physical board i am shorting, or is this a setting on the machine? Please if anyone can help
    Whatever
  • allan
    RTFM!!
    • 5462
    File format convertor
    does any body have part number for this on a 3025PS.
    Whatever
    • teebee1234
      • 1670
      It's an accessory so you won't be able to order it as a part.
      411400 (EDP code)- File Format Converter B
      • Starship2012
        Re: Using desktopbinder to download scaned documents
        What is the exact purpose of the File Format Converter Type B?
        • ccchuah
          • Mar 2009
          • 157
          Using Desktopbinder transfering data from document server only works on aficio 1045 & 1022 series model only.
          • Jomama46
            • 2900
            Data stored on the Doc Server is in a proprietary format and the FFC converts it to a format that can be read by the computer.
            The exact purpose is to make money by selling a board.
            sigpic
            A+; Network +; PDI+
            • Starship2012
              Thanks, knew if was a $$$$ thing. Does it allow me to see the temporary images from copies that were made ? I am looking for a document that was just copied that has the signatures on it.
              • Jomama46
                • 2900
                No, that copied doc is history, deleted after the print. Forensic software is your only hope. Deleted means the same here as on a computer, it is not erased but the FAT entry is gone. Wait too long tho and it may be overwritten.
                sigpic
                A+; Network +; PDI+
                • Starship2012
                  Can you recommend anybody who can take a shot at this drive? I have to try.
                  • Jomama46
                    • 2900
                    check this out. Home | My Hard Drive Died | Data Recovery and Training scott moulton is a genius.
                    sigpic
                    A+; Network +; PDI+
