I been working on this for a long time, the printer controler on this machine (Lanier 5813 - 220V) just stoped working, I couldt reinstal system software so we dumped the controler. Recently I have replaced that controler with another one, originaly from Aficio 6513 - 110V. Now I just cant calibrate colors, when calibrated print is dark and has a strong magenta, when calibration is removed the print is also dark but yellowish. When printing CMYK from controler colors come out fine...Copys also come out fine...any ideas...Thanks
Color Calibration
bjharrington
bjharrington
I tried from the panel. I just downloaded CWS, so I will try that now. I also read that it might be dirty AISD sensors. But not sure where to find those. Thanks.Comment
bjharrington
Thanks for the reply. I went into Setup Mode and under Color Setup the only choices for RGB Separation were "Output" and "Separation". I couldn't select "None". It was on "Output" so I'll try "Separation".
Thanks again for the help.Comment
