Windows 7 and Scan to folder
  • kwehner
    • Mar 2009
    • 47
    I have tried to setup scan to folder on several different Ricoh machines and the same thing happens every time.After you log in with the username and password I get the message "check settings" and after that the machine will not browse the network, until it is powered off\on. I cannot find any info in regard to scanning and Windows 7. I have turned the firewall and virus protection off and set the security settings as low as possible. Do the machines need a firmware upgrade?
    Ken
  • PinevskiS
    • Jul 2009
    • 284
    Other possibility is that WIndows 7 doesn't allow by default that a folder be shared without a password. So, if your trying to access the folder with a user without a password, it will block you.
    Go to "Network and Sharing Center" -> "Change Advanced Sharing Settings" -> Select "Turn off password protected sharing"
    • kwehner
      • Mar 2009
      • 47
      I have already tried that and it did not help.
      • teebee1234
        • Jul 2008
        • 1670
        Depending on the model/age of the mfp's you may have to upgrade the firmware. Vista and Windows 7 use a newer protocol of SMB and any machines that are more than a few years old will require firmware update. If they were using XP previously with no problems then this could be the issue.
        • Vulkor
          • Jun 2009
          • 942
          Program the Scan to Folder via the Web Image Monitor. That will work. Most MFP unless newest firmware will do what you described above.
          • verderacer
            • May 2008
            • 158
            it sounds like your dealing with a permissions issue.
            Ricoh & Microsoft may pay the bills but Un*x saves my ass every day.
            MCSE/CCNE/ENS and other crap...
            • Mr Spock
              Vulcan Inventor of Death
              • Aug 2006
              • 2064
              One thing I found is that the currently logged in user can not scan to the computer from the machine. I have IT setup another account on the machine just for the copiers to use for scanning. Also I have the machine use the password and include the account in the security permissions for the folder.
              • mikadonovan
                • May 2008
                • 2931
                This is the way we do it, too. (only way we could get it to work)
                NEVER ASSUME ANYTHING
                • Vulkor
                  • Jun 2009
                  • 942
                  Don't have to create Custom Accounts for Windows 7 Scan to Folder unless customer account is corrupt or user account has been renamed.
                  • kwehner
                    • Mar 2009
                    • 47
                    Upgrading the firmware and entering the scan to folder path through WIM has solved the problem on the B140 and B180 series machines. Thanks for all of your help!
