MP171F - Defaulting Fax method type to H.323
  • scoobysteve
    • Jun 2008
    • 163
    Hi,
    Just wondering if anyone knows how to default the fax method on a MP171SPF to H.323 (IP Fax) as opposed to G3?
    I have a machine where the clients do not want to have to go "TX Mode" --> "Select Line" --> "H.323" --> "OK" --> "Escape" everytime they fax as they only use IP Fax - no fax/telephone line.
    I know on the earlier MP161SPFs, if IP fax was configured, the left most button on the bottom of the LCD screen could toggle between which method you wanted to use. this still involved switching over to the H.323 protocol however it was one step whereas above there are many.
    Any ideas would be great. I've tried changing parameter setting switch 34 bit 0 to 1. I've gone into SP-1-107-07 and changed the priority to 1 etc but with no luck.
    any suggestions would be much appreciated. thank you.
    Kind Regards,
    Steve
