MP2000 on MAC OS X
  • hmac
    • Aug 2009
    • 129
    MP2000 on MAC OS X
    Hello, I install a MP2000SP, at a client who work on MAC OS 10.5.9.
    I managed to set the scanner. But I can not configure the printer.
    I tried different IP printing protocol:
    - DPA DAEMON
    - IPP
    - HP JETDIRECT
    I also download the latest version of Drivers provided by Nashuatec.
    But I still have the same problem! I print a page test, and the photocopier out several sheets
    white, or leaves with symbols.
    I can not find: x
    _________________
    HMac.
    _________________
  • dckm
    • 79
    Do you have "postscript" installed in the MP 2000?
    • cobiray
      Passing Duplication Xpert
      • Mar 2008
      • 1199
      You don't have postscript installed.
      • hmac
        • Aug 2009
        • 129
        I don't have postscript card installed on my MP2000. But I already tried to print on a MP1600, without the card and it worked.
        _________________
        HMac.
        _________________
        • cobiray
          • Mar 2008
          • 1199
          You will need the PS option to print to Macs.
          • iMind
            Vacuum Cleaning Expert
            • Mar 2008
            • 1116
            gutenprint for Mac OS it has a simple driver that will enable printing from your Mac with on need of a postscript card, just choose IPP printing put in an IP and it will find the driver the right driver by it self.
            • iMind
              • Mar 2008
              • 1116
              huuuuuuuuuuuuuum...
              • KenB
                Geek Extraordinaire
                • Dec 2007
                • 3944
                Take care when suggesting the Gutenprint drivers. I have found that they don't work with all models of Ricoh machines. Case in point: the MPC2050 / 2550. So be sure to check that your model is supported before attempting to install (or suggest!)
                • iMind
                  • Mar 2008
                  • 1116
                  Yes Sir! hehehe, in this case its a MP 2000 so It will work, As of what I know a MPc is a color machine, LOL...
                  • iMind
                    • Mar 2008
                    • 1116
                    • zozzhun
                      • Jan 2024
                      • 1
                      Re: MP2000 on MAC OS X
                      Hello. This is how I got working my Ricoh Aficio MP 2000 without card:
                      Added printer with LPD protocol with Generic PostPrict Printer use. Works flawlessly with duplex also.
                      Been using this for years. I just tested all possible methods years ago, then it just started working like this. Hope this helps others as well. Current Mac version: Ventura 13.6
                      • sandmanmac
                        • 3983
                        Seriously?
                        I'm sure that everyone that's been waiting 14 years for a solution (which was already posted) is breathing a little easier today
