Ricoh Aficio 450 Drum Charge roller get dirty to fast
  • m_donakov
    • 213
    Hi everyone i have ricoh aficio 450, and drumn charge roller get dirty every 300 copies. I open clean it and everthing become fine, after 300 copies agean black lines on copy and charge roller is dirty. Any Solutions
    Regrads
    Mile
  • TonerMunkeh
    Professional Moron
    • 3865
    Is the developer over life? It may be the dev unit's puffing a bit. Rebuild the PCU with new parts, check the entrance seals on the PCU and dev unit for signs of wear too.
    Hit it.
    • Fearless V K
      • 620
      Sounds like the drum cleaning blade is worn out, and/or lines worn in the drum allowing toner to get by the cleaning blade.
      Don't take that toner with me!
      • teebee1234
        • Jul 2008
        • 1670
        Also check the mag roller for coating. Brush away developer from the face of the mag roller, it should be shiny all the way across. When toner "melts" to the surface it acts as an electrical insulator and reduces the bias voltage in that area, causing background on the drum which will transfer to the charge roller. Replace the mag roller along with the developer if that's the case.
        • rthonpm
          • Aug 2007
          • 2849
          Is this a drum with the old style foam pad to clean the charge roller or the actual brush roller? If the former, modify it to use the brush roller and use the same brush you would for an LD035 or higher machine: the spines on the brush are better than the old plush ones and will last much longer.
          • mikadonovan
            • May 2008
            • 2931
            If your going to modify to use a cleaning brush, go ahead and put on the new style front and rear charge roller terminals. They work much better(like on a B079/B082)
            NEVER ASSUME ANYTHING
            • m_donakov
              • 213
              Thanks for your answer but there was drum cleaning pad problem, i replaiced and everthing is fine now thnaks to all
