I have these copier whit problem, at power on looks ok, but when push print button the copier indicate paper jamm, open door then close, and code sc 492 appear. clear code turn off, then on and code sc 501, appear.
I've check cooling fan, tray motor lift, and all is correct, please need help.
thanks in advance.
thanks in advance.
