Aficio 3245 Blurred Image
  • daveyball
    • May 2009
    • 314
    HI
    I have got 3245 with a slight blurr on Black only. Have tried new dev unit, and PCU and aslo Tarnsfer belt
    Anty Ideas
  • Polo-022
    • Sep 2007
    • 484
    What kind of blurr? (Vertical line at the middle of the print running from top edge to bottom edge?)
    Does this affect the resolution of a printed idol?
    • teebee1234
      • Jul 2008
      • 1670
      Originally posted by daveyball
      HI
      Anty Ideas
      Has anyone been working on the dev/drum drive in the back? I've seen the gears put on backwards (won't say who ) and that will give a blurred image. Could also be some chewed up teeth on the gear.
      • daveyball
        • May 2009
        • 314
        Its just a blurr on each individual character, much more noticable on small fonts, if you print the font page, the samller ones are worse than the bigger ones
        • teebee1234
          • Jul 2008
          • 1670
          If it's only blurry on the black and not the color then the problem most likely lies in the drum drive (Bk is a separate drive from the color). Check the gear teeth, but you may want to replace the motor and gear to be safe.
          • daveyball
            • May 2009
            • 314
            Turned out to be fuser unit. Gear that is driven by the machine, slightly worn. Thanks for the help
            • Vulkor
              • Jun 2009
              • 946
              Yeah we had this surprise us too one time. Was the Fusing Unit. Darndest thing.
