3224C Touch Screen Must be constantly re-calibrated
  • Solotime
    • 223
    Hi Guys,
    Have a customer with a 3224C that has to have the touch screen re-calibrated at least once a day as they have to touch the screen to the right of the button they actually want to use. It has gotten steadily worse over the last month or so when the problem started. Is this going to require a new touch screen? If so does anyone have a part number so I get get them a quote to repair.
    This machine has only about 4K color and 25K black copies on it.
    Thanks!
  • Eric1968
    • 2458
    There is an RTB out about faulty touch screens (RTB-41, Touch Screen Problem).
    • TonerMunkeh
      Professional Moron
      • 3865
      New part number H310 9900.
      Hit it.
      • iMind
        Vacuum Cleaning Expert
        • Mar 2008
        • 1116
        YEP, time to put in the new touch H310-9900 Ricoh does not charge you anything for the new touch, if you a dealer they shipping it for free until june 2010 so hurry up...
        sigpicWe can all Win, but at the end we all loose. Save the greyhound
        • Solotime
          • 223
          Thanks guys.....I have read the related posts concerning these displays but did not think it applied to this machine. Are we sure this applies to a 3224C? It is about what 5 or 6 years old now. I ask this hoping I do not affend anyone. Just want to make sure.
          • iMind
            • Mar 2008
            • 1116
            • knightfall
              • Jul 2006
              • 633
              I had similar problem on a color copier but it happens only when they shut the copier off then on, we would calibrate it then the next day the touch screen would need calibration again. The lcdc is where the touch screen calibration is stored. You can try and change the touch panel but since its only an input device and the bulletin is for the adhesive of the connector it would not do any damage since its free replacement but if it doesn't work try reloading the firmware for the lcdc and if necessary replace the lcdc board, replacing the lcdc board resolved my problem. Good luck.
              Get your facts first, and then you can distort them as much as you please.
              • TonerMunkeh
                Professional Moron
                • 3865
                The 3224C has been included in this RTB because it has the same touch screen. Machines also included are some of the wide format stuff too.
                Hit it.
                • Solotime
                  • 223
                  Thanks for the info. As I am an independant service guy I do not get the freebie from Ricoh. But I do have 2 1224C models which share a lot of the same parts. Can anyone with access to manuals or knowhow tell me if the ops panel / touch screen / lcdc can be swapped with the 3224C? This customer is a Church with out a lot of money so I am trying to find them a reasonable solution.
                  Again thanks in advance for any help you can offer.
                  • Eric1968
                    • 2458
                    Look at the post of Tonermunkeh above your post!
