Problem With Ricoh Aficio 850 Light Copies
  • prepella
    • Jun 2025
    I have been working on my 850, we had problem with light copies and prints for the printer
    replaced, the drum, developer and corona wire, still the same, very light print, anyone
    have any suggestions where to go next?
    Phil
  • Vulkor
    • Jun 2009
    • 946
    Don't know anything about this, but there is a troubleshooting guide/Bulletin released by Ricoh on this model that has to do with LIGHT COPIES. Bulletin # 85
    • prepella
      My bulletin's stop at #76, can you email me #85?
      • Vulkor
        • Jun 2009
        • 946
        PM me your info. Can't figure out how to upload PDF attachments only links and images.
        • tcs04
          FORMER Techie
          • 1183
          Phil
          Sounds like poor earth on the drum shaft. remove flywheel, check the resistance betwen the shaft and brass contact, remove brass contact plate from hub, clean the contact brush, stick a rag throught the hole in the hub and clean the shaft. If this makes a difference but is not perfect change the hub / shaft assembly.
