Ricoh Error Codes
  • Kenardo
    Ricoh Error Codes
    Is there some online resource where we can get a list of common Ricoh Error Codes, specifically for the Afficio MP 1100 series. We have five of these, and while we know SOME error codes, it would still be great if we had a resource that has more.
    On a side note... anyone know what SC750 error is?
  • Cipher
    It's not easy being green
    • May 2006
    • 1309
    SC750 - Upper tray lift for the B830 finisher.
    The upper tray paper height
    sensor does not change its
    status within 20 sec. after the
    tray raises or lowers. The 1st
    detection failure issues a jam
    error, and the 2nd failure issues
    this SC code.
    • frank
      Re: Ricoh Error Codes
      I have several Ricoh Aficio 3030 that I have purchased and all have error code sc870-01 on them.I suspect that they are all from government departments,where the HDD have been removed.
      Are these HDD obtailable or can they be formated with any similar HDD.
      • jonezy999
        just one copy??
        • Feb 2010
        • 952
        Step 1. Go to the newbie check in forum.
        Step 2. Say Hi.
        Step 3. Start a new thread for your issue.
        I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
        • Jomama46
          • 2900
          Step 2. Say Hi.
          Tell'em Jonezy!
          sigpic
          A+; Network +; PDI+
            • 23009
            I know this is a crazy idea, but how 'bout buying a manual?
            Who knows? You might need to run a simulation or look up a part number. Do you expect somebody here to do your due diligence, your research?
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              I can smell end user all over em
              • banginbishop
                grumpy old git
                • Oct 2007
                • 894
                I say we start a new post in rants rave and burn an effigy of blackcat as im bored to hell of seeing one for manuals for you. if he burns he's a witch if he dont burn he's a witch - burn him burn him. Yeah its been a long week!
                Incontinentia Buttocks
                • Jomama46
                  • 2900
                  Banging, you need a drink (or 3)
                  sigpic
                  A+; Network +; PDI+
                  • banginbishop
                    grumpy old git
                    • Oct 2007
                    • 894
                    tell me, got an interview wednesday as well so its keeping me awake at night just thinking about it.
                    • Jomama46
                      • 2900
                      Good luck. Me and Johnny Walker are drinking to your health as we speak.
                      sigpic
                      A+; Network +; PDI+
                      • jummamaster
                        • Mar 2009
                        • 99
                        Originally posted by lionheart
                        A brief description is here:
                        Printer's Solutions: Ricoh Error Codes
                        Updated link of this article:
                        Ricoh Error Codes
                        Ricoh Error Codes
                        Canon Error 5100
                        Canon Error B200
                        j
                        c
                        • Nikola
                          • Mar 2008
                          • 6
                          what is sc 494 on ricoh mp 1100? thanks
                          • Jomama46
                            • 2900
                            Clean and check toner supply coil, tube, clutch and torque limiter
                            Usually just clogged.
                            sigpic
                            A+; Network +; PDI+
                            • Andy6096
                              • Aug 2009
                              • 14
                              Read Edgar Allen Poe "The Black Cat"
                              LMAO
                              Make yourself invaluable to everyone whether you're around or not.
