MP171 SPF No Connectivity
  • Voltage
    • Jul 2008
    • 282
    HI
    Anybody ever had a MP171SPF with no connectivity. Green light goes on when i plug in network cable.
    I did check the device setting SP and it is on 1. Removed HDD. Still no joy.
    Any ideas?
  • PinevskiS
    • Jul 2009
    • 284
    See on Printer controller where you put the LAN maybe in LAN port you have wire a damaged, or the printer controller is not connect properly.
    • Jomama46
      • 2900
      Any messages on the display?
      Can you ping it?
      possibly mixed up the snm and gateway?
      Did you confirm the IP is OK by looking at the settings on a working workstation?
      sigpic
      A+; Network +; PDI+
      • Voltage
        • Jul 2008
        • 282
        Any messages on the display? NO
        Can you ping it? NO and you can not ping from it.
        possibly mixed up the snm and gateway? Is doing it at the customer and in the workshop
        Did you confirm the IP is OK by looking at the settings on a working workstation? IP is ok
        I think the BICU board is buggered but i do not want to order one unnecessarilsy
        • Vulkor
          • Jun 2009
          • 942
          Had one of these NIC interfaces get fried from a surge once. Just like yours. Nic Light lit up, Was able to enter all IP info, but no love for pring or scan or anything Network Based.
          Try printing via USB. If that works then the Controller is shot because the NIC is built into it on these models if I recall.
          • df3036
            • 109
            I have had on some older machines (2232c) that if the network card looks bad, reflash it even if the firmware is up to date. Worth a try...
            Kittens give Morbo gas.
            A+, Network+, Server+, PDI+
            • Jomama46
              • 2900
              Yep sounds like a board but if it were me I would connect to it with a crossover and laptop first.
              sigpic
              A+; Network +; PDI+
              • pocket aces
                Ricoh Technician
                • Nov 2008
                • 72
                I had this on mp171 green light comes on cant print cant ping..... it was the network cable got another one worked just fine....what threw me off was the green light comes on when you plug it in .....just a thought
                • neergish
                  • 177
                  Had the same issue on an 171spf install about 12 months ago, went through every thing twice, spent hours on the phone to the customers IT, reloading firmware and talking to ricoh tech support, I even got sent a replacement controller board to swap in, but in the end it turned out to be a setting.
                  changed IEEE802.IX AUTH (ETHERNET) to INACTIVE, (cant remember where this is exactly, somewhere under user tools)
                  after that it worked like a charm.
                  "See if you can rent a spring hook and a phillips screwdriver it will make your life that much easier..."
                  • D_L_P
                    Self Employed
                    • Oct 2009
                    • 1196
                    Sounds like Neergish might have a solution for you. Might be related but if that doesn't work try manually locking in the LAN speed. I don't want to steal another guy's thunder, but KenB said he had to do that before. I guess his Gigabit ethernet cards couldn't auto-negotiate the speed.
                    • zed255
                      How'd ya manage that?
                      • 1025
                      Had this also on an MPC2500, just a crap cable. Must have been either mis-wired or only an issue with one pair or something like that.
                      • Voltage
                        • Jul 2008
                        • 282
                        Awesomeness. That seem to do the trick.
                        Thanks Dude
                        • Vulkor
                          • Jun 2009
                          • 942
                          Why the heck would that Setting
                          Even be turned off?
                          • neergish
                            • 177
                            Originally posted by Vulkor
                            Why the heck would that Setting Even be turned off?
                            From what I can gather IEEE802.IX AUTH has something to do with wireless communication. According to the "Network and Systems Settings Guide" this should be set to inactive by default, perhaps the problem only occurs when it is set to active and there isn't a wireless card installed into the machine. The 171 I had issue with was brand new out of the box, I'm guessing that the setting may have been changed from default whilst testing communication modes at the factory. A lot of supposition I know, but suffice to say that after my adventures last year it is now something I check everytime I run up one of these boxes.
