Ricoh 1013
  • tcypy1961
    • 773
    Ricoh 1013
    What would cause a line on the drum? I've replaced the drum blade with no success and I've taken a drum unit from another 1013 and get the same problem with it. Is this just strictly a drum unit problem or could something else in the copier be causing this problem? If you open the side door on the copier and look at the drum unit you will see that the line is on the left side of the drum, or close to the front door. Any help appreciated, thank you.
  • Eric1968
    • 2459
    Replace the Hot Roller/Stripper Pawls. Or let the paper jam to see if it's drum or fusing unit related.
    • TonerMunkeh
      Professional Moron
      • 3873
      Do you rebuild 1013 PCU's? Might be the charge roller's had it.
      Hit it.
      • nos
        • Nov 2008
        • 78
        Ricoh 1013
        I know this sounds really stupid, but we fought with one doing the same thing. We called Ricoh and they said "dont laugh" its the ground on the paper tray. We adjusted the metal grounding tab on the back of the tray and the line went away for good. I know it sounds stupid, but give it a try.
        • Fearless V K
          • 620
          There's a TSB for that.
          Don't take that toner with me!
